1987 Toyota Pickup Front wheel tighten up on hard right tur
1987 TOYOTA PICKUP
HAYWOODWHY
Suspension problem
1987 Toyota Pickup 4 cyl Four Wheel Drive Manual 95.000 miles
When I turn right in a tight turn my front wheels act like I am putting the brakes on.Front rotors, brake calipers, brake master cylinder have all been replaced with new oem parts. Front hubs use AISIN lockouts, which turn freely and lock/unlock the hub.
Sep 8, 2008 at 11:05 AM
BLACKOP555
  • 10,386 POSTS
jack up entire vehicle and put the wheels to the place when you notice the wheels starting to bind, then rotate the front wheels. do they bind?
check to make sure no hoses are being pinched or pulled and the wheels rotate freely straight ahead or when turned to the right left etc.
if that looks good i would definetely be checking the rear end.
Sep 8, 2008 at 11:15 AM
