1987 Toyota Pickup carburetor
14,500 MILES • 4 CYL • 4WD • MANUAL
WEWEWE
I just change the carburetor numbering and making
sure vaccum hoses are correct. I can not get the
carburetor to prime. It looks lack the fuel bowel is
not filling up. I can not see any fuel through the view
window on the front of the carburetor. what am I
doing wrong? I tried pouring gas into the top of
the carburetor. thanks if you can help
Apr 25, 2010 at 10:02 AM
  • 75,988 POSTS
Check if you have the correct fuel pressure if okay-check the needle inlet valve and the float
Apr 26, 2010 at 9:17 AM
