1987 Toyota Pickup carburator
285,000 MILES • 4 CYL • 4WD • MANUAL
ZACKYB69
sorry if i posted wrong ill try it again. im having trouble with excessive fuel in the primary venturi. i rebuilt a different carb that didn't have this problem and now both carb are doing the same. i plugged the port and it will idle fine but as you know it won" accelerate
Mar 27, 2009 at 5:17 AM
  • 75,988 POSTS
Check the Carb's accelerator, main metering and power valve circuit.
Mar 27, 2009 at 5:25 AM
