1987 Toyota Pickup carb problems toyota pkup 22r
285,000 MILES • 4 CYL • 4WD • MANUAL
ZACKYB69
sorry for delayed response. manifold pressure is about14 to 16 psi fluctuating slowly. found valve cover gasket leak and repaired. helped greatly but still having same problems with excessive fuel in the prim. venturi
May 2, 2009 at 6:34 AM
  • 75,988 POSTS
Try adjusting the A/F mixture screw don't work time to rebuld it
May 2, 2009 at 8:09 AM
