1987 Toyota Pickup
1987 TOYOTA PICKUP
SHELIA BENNETT
Electrical problem
1987 Toyota Pickup 6 cyl Four Wheel Drive 169,00 miles
I have replaced my battery. the only way I can keep it charged is take the hot wire off when i park it.Otherwise the battery will be dead.What could cause this? My alternator has been tested and is ok.
Jan 7, 2008 at 10:43 AM
  • 31,937 POSTS
Hi there,
You will have to do a current draw test, place an Amp meter between the battery (+) and the cable removed this will show any current draw, with key off and door s closed you should have about .1-.25 amps max if more, start to pull fuses to locate circuit drawing power. The alternator may be leaking ton earth (this will not affect charging a lot) but pull off main alternator cable as well to see if the current draw is there.
Mark (mhpautos)
Jan 7, 2008 at 11:10 AM
