1986 Toyota Pickup willnot start but cranks
107,000 MILES • 4 CYL • 2WD • AUTOMATIC
HELLCATS
i donot think its fireing i cannot see a spark or ark this is a motorhome i started it once a month and it started just fine now i went to start it and it just cranks lights and radio all work i need to go camping next week what will help me get it started..... i think its a circuit opening relay but donot no what to look for or how to track it down thanks brian
May 9, 2010 at 1:11 PM
  • 75,988 POSTS
Do below and get back with some results:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 9, 2010 at 3:27 PM
