Hey there,
I've got a 4 wheel drive 1986 toyota pick up. I'm trying to replace the rotors. I have the rotor/hub assembly off. I've removed all the bolts holding the rotor to the hub unit, but still can't separate the two.
Do I need to disassemble the hub?
Are there two parts to the hub?: an inside bearing housing and an exterior that "sandwich" the rotor?
Thanks so much.
Thanks so much.
Jun 14, 2008 at 1:15 AM
