1986 Toyota Pickup Headlights
128,000 MILES • 4 CYL • 2WD • MANUAL
DAROLD SLANE
When I turn on my headlights they are not as bright as they should be. When I push on the accelerator, the headlights get brighter. I replaced the battery with a brand new battery but headlights react in the same manor. What is causing this headlight variation in brightness.
Nov 19, 2009 at 7:39 PM
JDL
  • 16,098 POSTS
Hi, did you have the charging system checked? The alternator output is usually dependant on engine rpms.
Nov 20, 2009 at 3:47 AM
