I have a Toyota Hilux "Light truck" with the petrol 3Y engine of 2L capacity which is a "research" vehicle. My manual (Haynes) and visual inspection of the carburetted naturally aspirated engine reveal a fuel feed and return line system as well as a "vapour line", but I have no description how the fuel system operates. Everything works a it should. I'D LIKE TO INSTALL A FUEL FLOW METERING DEVICE somewhere in the line(s) working on the principle of a rotameter, or paddlewheel. The electronic microcomputer with it counts down from a volume of fuel entered into memory. WHERE DO YOU SUGGEST I INSERT THE METER ? I am a pensioner. Many thanks. Rod
Oct 24, 2009 at 7:09 PM
