The engine temperature gauge fluctuates. I have the 2.2RE engine. About 1 year ago, the temperature gauge would occasionally go from normal reading (mid range) to redline, than return to normal within a few seconds. This seemed like a bad thermostat. It does this while driving at constant highway speeds, at stop lights, etc.
I replaced the thermostat and sensor. The situation has gotten worse over the past few months, the needle continually moves up to red line, than returns to mid range.
Is the mechanic thinks it may be the gauge itself. What do you think?
Feb 29, 2008 at 4:18 PM
