1986 Toyota Pickup engine stalling
200,000 MILES • 4 CYL • 4WD • MANUAL
BILLYDILTZ
engine starts & runs fine until you get to 2500 rpms & then it starts missing like it is starving for fuel. tps seems to be working fine. new fuel filter. started it one day & it ran fine for a few days & now it is doing the same thing again.
Jun 16, 2010 at 11:27 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay test the EGR valve and airflow meter. Could also be that your clutch is slipping
Jun 16, 2010 at 11:35 AM
