1986 Toyota Pickup cluch master
YANCY CAVE
Transmission problem
1986 Toyota Pickup 4 cyl Four Wheel Drive Manual
master rod that hooks to pedal seems to be too
long and is bottoming out aginst pedal causeing
the plunger to go in at an angle. Is that a common
problem and is it ok to cut it?
Nov 18, 2008 at 11:26 AM
  • 31,937 POSTS
Hi there ,
The end attach point should be threaded and is adjustable, back of the lock nuts and wind it in you want a bout 2mm free play.
Mark (mhpautos)
Nov 18, 2008 at 1:59 PM
