1986 Toyota Pickup carbureator
1986 TOYOTA PICKUP
121,000 MILES • 4 CYL • 4WD • MANUAL
GIE2
my carb is ideling high, how may i correct this? would the ideling speed cause an increase in gasoline usage and reduce the mpg? thanks
Aug 14, 2008 at 5:30 PM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
there can be a number of reasons why the idle is to high, base idle setting, a stuck choke valve, sticky choke idle up, A/c idle up stuck on, an internal fault with the carby. a problem with the distributor vacuum or engine timing take your pick, so i would get a mechanic to inspect this for you rather than experimenting with the settings.
Mark (mhpautos)
Aug 14, 2008 at 5:44 PM
