1986 Toyota Pickup battery
1986 TOYOTA PICKUP
20,000 MILES • 4 CYL • 2WD • AUTOMATIC
TERROLD051548
HOOKED THE BATTERY CABLES BACKWARDS AND BLEW MOST OF THE FUSES WHEN THE KEY WAS TURNED ON. i REPLACED THE FUSES AND FIXED THE CABLES. THE LIGHTS COME ON AND ENGINE TURNS OVER BUT THE ENGINE WON'T START. wHATS WRONG? Do I need to replace the coil?
Oct 6, 2008 at 7:54 AM
ROB2008
  • 258 POSTS
What you need to do first is check for spark . pull the spark plug wire off and ground it close to the engine .. have a helper turn the engine over , if you see a blue spark between the frame and the wire then the coil is good .Test the coil if no spark .
Reply back if you need any help.
Oct 8, 2008 at 4:33 AM
