1985 Toyota Pickup pilot bearing
1985 TOYOTA PICKUP
JJBONZ
Transmission problem
1985 Toyota Pickup 4 cyl Two Wheel Drive Manual
do you have to take out trans to check or remove pilot bearing
Jan 15, 2009 at 11:15 AM
KHLOW2008
  • 41,814 POSTS
Hi jjbonz,
Yes, the pilot bearing embedded in the crankshaft and the transmission clutch shaft sits on it.
If the pilot bearing is bad, you would get a grinding noise when clutch is depressed with gears engaged and vehicle running.
Gear shifting would tend to crash if the bearing is seized or partially seized.
Jan 18, 2009 at 4:48 AM
