1984 Toyota Pickup water pump
25,000 MILES • 4 CYL • 4WD • MANUAL
PAM275
I am trying to find out if my water pump is going out. My radiator is still circulating water, but there is water leaking between the bell housing and the motor. There is coolant in my system and the coolant is present in the water that is leaking.
Oct 27, 2010 at 10:24 AM
  • 75,988 POSTS
The leak in that area is due to a freeze plug leaking-double check the intake manifold and heater hoses
Oct 27, 2010 at 9:53 PM
