1984 Toyota Pickup TIMING MARKS ON THE SPROCKETS
160,000 MILES • 4 CYL • 2WD • MANUAL
DCHAP110
hi. im putting a new timing kit in my 1984 22r motor should both timing marks on my camshaft sprocket and my crank sprocket be pointed up in the same direction? thanks
Jan 31, 2008 at 12:28 AM
DAKOTABRU
  • 11 POSTS
[quote="dchap110"]Engine problem
1984 Toyota Pickup 4 cyl Two Wheel Drive Manual 160000 miles
make sure key in crankshaft is at 12 o'clock position. Align bright chain links with timing marks on the crank and cam. turn chain clock wise to take up slack. Make sure distributor is not 180 degrees out.
Feb 2, 2008 at 5:23 AM
