My 1984 Toyota pickup is having brake problems when i brake it goes to the left pretty quick and will not stop after bleeding the lines properly and adding the required DOT5 fluid (autozone) do you guys have anyother ideas other then getting it realigned which les Schwab did last fall
Jun 14, 2010 at 11:33 PM
