1983 Toyota Pickup willnot start low compression
20,100 MILES • 4 CYL • 2WD • MANUAL
SLIGHT50
my truck got hot and stalled after it cooled down it will crank but not start.
Jan 20, 2008 at 9:18 PM
  • 75,988 POSTS
Spray carb cleaner in the Carb or Throttle Body -if it fires up-you have a fuel problem if not its an ignition.
Disconnect a sparkplug wire and ground it to the engine and have helper crank engine over-do you have a snapping blue spark?
Jan 22, 2008 at 4:42 AM
