1982 Toyota Pickup clutch
439,683 MILES • 4 CYL • 2WD • MANUAL
CATFISH8
My 1982 toyota pickup hadnt been ran due to engine problems for about a year. I fixed the problems and ran it today. I went up a steep hill and then around the neighborhood and the clutch pedal became very loose. It has no pressure and when i acelerate it revs up to 4000 rpm's and hardly goes anywhere? If its the master clutch whats the best way to install a new one?
Jun 4, 2009 at 11:50 AM
  • 75,988 POSTS
Sounds more like you need a clutch assembly-up to 4k rpm and hardly moves-its slipping
Jun 4, 2009 at 11:55 AM
BILLYMAC
  • 2,204 POSTS
the best way and least trouble is buy the clutch master and slave already assembled and install and cut the wire tie and you have clutch. if can,t buy complete then you must bleed system.. goodluck billymac
Jun 4, 2009 at 11:58 AM
