1980 Toyota Pickup thermastat
150,000 MILES • 4 CYL • FWD • MANUAL
VIRCEN
where is the thermastat of a 1980 toyota pickup
located
Aug 15, 2010 at 9:15 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Partially drain the cooling system. Unless the upper radiator hose is positioned over one of the thermostat housing (water outlet) bolts, it is not necessary to detach the hose. Remove the bolts and remove the water outlet. When installing a new thermostat always use a new gasket. Be sure that the thermostat is positioned with the spring down. The factory recommended thermostat temperature is 180 ° for all engines.
https://images.2carpros.com/forum/automotive_pictures/261618_1_188.jpg
Aug 15, 2010 at 9:17 AM
