1980 Toyota Pickup hmm
1980 TOYOTA PICKUP
DRJJR
Engine Mechanical problem
1980 Toyota Pickup 4 cyl Four Wheel Drive Manual 65k miles
I replaced my head gasket, exhaust manifold gasket, intake manifold gasket and still getting chocolate milk for oil and blowing white smoke out the exhaust ... any ideas what to replace now ? water pump ? please help thanks
Dec 3, 2009 at 3:42 PM
  • 31,937 POSTS
Hi there,
Did you have the head crack tested and checked for bend?
Mark (mhpautos)
Dec 3, 2009 at 3:47 PM
DRJJR
no the head was really stained with oil and i hand sanded it and just visually checked everything the cylinders look'd like they were in great condition cant really afford to have someone else look at it.
I dont think its cracked or bent
Dec 3, 2009 at 4:09 PM
DRJJR
i just want to figure out what else i need to replace this started about a week ago and i havent driven it since i noticed it. I drove through about 4 ft of water but the truck has 40" tires and a 12" lift kit on it. Its 30 years old and was running great till I did that yet its been used as a mud truck for a long time.
Dec 3, 2009 at 4:25 PM
DRJJR
when i start it it runs without smoking for about 30 seconds then it seems when the thermostat on the hose coming out of the top of the radiator goin to the intake manifold clicks on it starts blowing white smoke if i squeeze this hose it REALLY starts smoking.. :C
Dec 3, 2009 at 5:12 PM
  • 31,937 POSTS
Cracked heads are often not visible with the naked eye, often they are inside the valve ports, these alloy heads do bend & twist you only need .015" or so bend foe a problem, i do feel that the head is the problem and it needs looking at professionally,
Mark (mhpautos)
Dec 3, 2009 at 5:47 PM
