Electrical problem
1978 Toyota Pickup 4 cyl Two Wheel Drive Manual
i have power going to the coil, but pick-up truck engine, while it cranks will not start. I removed the coil wire from the dustributor, cranked the engine, but not arcing from the coil distributor wire. Besides the obvious n/g coil, is there any way to test the coil while still in the engine, or does it have to be removed to test.
thank you
andy reynolds jr.
thank you
andy reynolds jr.
Jul 15, 2008 at 8:30 AM
