1976 Toyota Pickup
DENTONBURTON
  • 1976 TOYOTA PICKUP
  • 4 CYL
  • MANUAL
  • 180,000 MILES
The engine starts just fine, runs good, but dies after 10 to 20 seconds. I repaced the carb foat. I measured 3 ounces of fuel from turning engine over about 10 times.
Thursday, November 20th, 2008 AT 4:23 PM
  • 31,937 POSTS
HI there,
Will it run if you hold the revs up over 1500RPM?
Mark (mhpautos)
Thursday, November 20th, 2008 AT 4:27 PM
DENTONBURTON
  • 8 POSTS
No! It dies no matter what rpm I run it at.
Thursday, November 20th, 2008 AT 4:30 PM
  • 31,937 POSTS
Will it re start straight away? Do you have spark all the time?
Mark (mhpautos)
Thursday, November 20th, 2008 AT 4:37 PM
DENTONBURTON
  • 8 POSTS
It dose restart after pumping the gas pedal a few times while turning the engine over for a few seconds.
Thursday, November 20th, 2008 AT 4:40 PM
  • 31,937 POSTS
OK, look at this, get it running again, let it stall, with the air cleaner removed look into the carby and pump the throttle, is there fuel spraying into the carby?
Mark
Thursday, November 20th, 2008 AT 5:12 PM
DENTONBURTON
  • 8 POSTS
No fuel spraying into carb after it dies and I pump the throtle.
Thursday, November 20th, 2008 AT 5:19 PM
  • 31,937 POSTS
OK, then you have a fuel pump problem, or a sticky needle and seat, undo the fuel line into the carby and place a tube over it, run this into a jar, crank the engine, you should have a good flow of fuel, check this.
Mark
Thursday, November 20th, 2008 AT 5:52 PM
DENTONBURTON
  • 8 POSTS
I've done this. But I don't know what is a "good flow". I cranked the engine over about 10 times and got 3 ounces of fuel.
Thursday, November 20th, 2008 AT 5:57 PM
  • 31,937 POSTS
Hi there,
You should have a constant pulsating flow, I would say the pump is faulty change that and the filter.
Mark (mhpautos)
Thursday, November 20th, 2008 AT 6:06 PM
DENTONBURTON
  • 8 POSTS
Thank you! One final dumb question. Where is the fuel pump? It's not on the engine or the fuel tank. I guess it is an inline pump somewhere under the chasie.
Thursday, November 20th, 2008 AT 6:13 PM
  • 31,937 POSTS
As I am in Australia I am unsure as to what they have there on your models, can you give me a chassis code it will be some thing lie RN 65 if I have that I should be able to tell you, but I think that they are a mechanical pump driven of the cam at the front of the head, have a look
mark (mhpautos)
Thursday, November 20th, 2008 AT 6:52 PM
DENTONBURTON
  • 8 POSTS
The fuel line runs from the carb to under the chasie to the fuel tank. I'm positive there is no fuel pump on the engine. My VIN is: RN28033581
Thursday, November 20th, 2008 AT 6:57 PM
  • 31,937 POSTS
I have had a bit on a look on the web, and it looks like it is an in tank electric pump.
Mark (mhpautos)
Thursday, November 20th, 2008 AT 7:08 PM
DENTONBURTON
  • 8 POSTS
Thanks for your help. Bye.
Thursday, November 20th, 2008 AT 7:47 PM
