Toyota Passo 2007 Engine not working properly
2007 TOYOTA PASEO
55,399 MILES • 1.0L • 3 CYL • FWD • AUTOMATIC
RDAMILA
I brought a toyota passo 2007 model couples months ago now i had a problem for engine.it is not working properly. When I am driving my car some time it's suddenly stop. That time I was tried to start my car but its couldn't for me.Now its happen most of time.
how ever I check my car functionality as follows,
*Fuel filler is normal but I think need to replace
*Fuel pumping presser is good
*Radiator cooling fan working and run several mints then stop.(it is not always running)
*Engine compressor is good
*AC is working well
*Never see indicate check engine light
*No any computer errors
Please refer following facts
*Battery power is good
*I used recommended Toyota engine oil and coolant
Apr 14, 2014 at 4:52 AM
HMAC300
  • 48,601 POSTS
check fuel pressure with a gauge we don't have that model in u.s. also have it scanned for codes.
Here are a couple guides that will help with this.
Please let us know what you find with this. Thanks
Apr 14, 2014 at 6:51 AM
RDAMILA
Thank you for your quick attention.There is no any computer error codes.
Still I haven't any solutions.
Apr 16, 2014 at 8:22 AM
HMAC300
  • 48,601 POSTS
reread my first reply fuel pressure has to be checked with a gauge not just seeing if it 's there. pressure shold be around 44-50 psi or at least that is a corolla which yours is similar to
Apr 16, 2014 at 9:40 AM
RDAMILA
Sorry for my misunderstanding about your reply. I will check fuel pressure and update the status soon as possible.
Apr 17, 2014 at 11:09 PM
