1997 Toyota Paseo Noisy transmission
1997 TOYOTA PASEO
228,000 MILES • 4 CYL • FWD • MANUAL
STANG007
  • 29 POSTS
I realized that my transmission was making noise when engaging it (realesing the clutch pedal). It seems to make more noise on 4th and 5th gears.When I press on the clutch, the noise stops. The clutch dosen't slips and the car dosen't seem to have a loss of power or anything. Would it be a bearing?? Can i use the car safely??
thanks
Sep 4, 2008 at 2:12 PM
  • 31,937 POSTS
HI there,
this dose sound like a bearing problem, i would have the oil changed as a precaution, it will only get worse so don't put off the repair as the longer you do the more damage you may do.
Mark (mhpautos)
Sep 4, 2008 at 6:15 PM
