I am having to replenish the oil every few weeks. Just had car for about 6 months and added about 4litrs to date.
Apr 10, 2008 at 7:55 AM
✓Experienced Mechanic
If there's no actual leakage then its being burn in the combustion chamber-recommend a compression and leakdown test possibilities: Valve/seals/stems/guides/rings etc-
Apr 10, 2008 at 9:15 AM
PASEO SI
MEMBER
[quote:474f05799b="rasmataz"]If there's no actual leakage then its being burn in the combustion chamber-recommend a compression and leakdown test possibilities: Valve/seals/stems/guides/rings etc-[/quote:474f05799b]
Thanks for that.Will get test done asap.
