1995 Toyota Paseo Fuel Pump
1995 TOYOTA PASEO
RDOSS3
Electrical problem
1995 Toyota Paseo Two Wheel Drive Automatic
How do you change the fuel pump on a 1995 Toyota Paseo
Aug 10, 2008 at 9:49 AM
Assess door -Remove rear seat and cover plate and you're right there-you sure its the fuel pump?
Aug 20, 2008 at 1:06 PM
RDOSS3
Well almost, When you turn on the ignition I hear no sound like the fuel pump running and no fuel is making it to the injector body. I did a stupid thing I learned later and will not do again, but sprayed starter fluid into the injector body and the engine ran ok. Found out that could be a very expensive mistake if the engine backfired so will not try that again. Have tried to find a fuel pump relay to no avail.
Aug 20, 2008 at 3:11 PM
but sprayed starter fluid into the injector body and the engine ran ok:
Did it continue to run without the fluid or running while you spray on it?
Aug 20, 2008 at 3:32 PM
RDOSS3
It ran as long as I sprayed starter fluid into the injectors but would die after it burnt up the starter fluid. Like I said No gas was being pumped to the engine.
Aug 20, 2008 at 7:12 PM
Do you hear the fuel pump come on? If so check the fuel pressure this wiil take you to a failed fuel pump-if pressure is okay-could be that the injector/s are not pulsing meaning its not opening and closing to provide fuel to the cylinders.
Aug 20, 2008 at 9:37 PM
