1994 Toyota Paseo Timing belt:
1994 TOYOTA PASEO
OLDFARTRUS
Engine Mechanical problem
1994 Toyota Paseo 4 cyl Front Wheel Drive Manual
Is the paseo engine a " non-interference type"?
Will a broken timing belt result in engine/ valve/ piston damage?
Thank you
May 2, 2008 at 10:29 AM
No its not an interference engine.
Will a broken timing belt result in engine/ valve/ piston damage? If it is an interference engine-
May 2, 2008 at 10:39 AM
