Hey, I'm trying to replace the driveshaft on my 94' Toyota Paseo and there are serious rust problems preventing it. I managed to loosen the axle nut with a torch and leverage pole. The problem is with the lock nut that holds the shaft and the ball joint together and also the brake caliper nuts. They will not budge. I've tried a torch, rip tite sockets and a chisel. They are very stripped. Is there anything I can do?
Any helpful advise would be much appreciated.
Aug 12, 2009 at 3:43 PM
