1994 Toyota Paseo ignition
202,872 MILES • 4 CYL • 2WD • MANUAL
KENHERM
when I turn the key to start the engine some times all I hear is a click from under the dash some where. I will try several times before the engine will finally start. It is getting worse the other day it took over 5 minutes of trying. But some times it will start on the first try. do not know if it is the ignition swich or so other problem.
May 22, 2010 at 9:35 AM
  • 75,988 POSTS
Check and test the EFI relay, Circuit Opening relay and the ignition switch
May 22, 2010 at 12:51 PM
