1994 Toyota Paseo check engine light
KATYJO
Engine Mechanical problem
1994 Toyota Paseo 4 cyl Front Wheel Drive Automatic 155k miles
I just had an o2 sensor and a fuel filter put on my car because my check engine light would come on and off and then finally stayed on. I almost made it home tonight and the check engine light came back on. what can it be. i cannot find a shop that will scan it for the code.
May 27, 2008 at 2:51 PM
  • 31,937 POSTS
Hi there,
You will have to get the code before i can help, there are so many things that will set a code, most work shops have scanners so just make a few phone calls.
mark (mhpautos)
May 27, 2008 at 6:56 PM
