1994 Toyota Paseo carburetor
185,000 MILES • 4 CYL • FWD • MANUAL
EDDIE7777
i was cleaning my carburetor with carb spray. It had alot of black gunk built up. I then wiped it out and put the air hose back on. It know idles at 2000. Why would cleaning the carb adjust the idle speed? I made no adjustments, all I did was spray and wipe. Should I adjust the carb and how exactly do I do that?
Aug 21, 2010 at 2:49 AM
  • 75,988 POSTS
You sure you have a carbuerator or a throttle body injection system
Clean out the idle air control valve and see what happens
Aug 21, 2010 at 9:17 AM
