1993 Toyota Paseo just cut off
183,555 MILES • 4 CYL • FWD • AUTOMATIC
TINESHIA.COOPER
my car just cut off as i was driving. it cranks up, but doesnt turn on. my battery light came on too. i have a little oil leak problem but i keep regual oil changes and makes sure there is oil in it.
Oct 11, 2009 at 2:50 PM
  • 75,988 POSTS
Do below to determine if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Oct 11, 2009 at 10:04 PM
