1993 Toyota Paseo engine trouble
194,000 MILES • 4 CYL • 2WD • AUTOMATIC
DELOA
while driving the car at 35 mph car lost power and completely stop. I try to start it but it did not ignite
Oct 26, 2009 at 5:50 PM
  • 75,988 POSTS
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
If spark and fuel present check the valve and ignition timing to rule out the belt
Oct 26, 2009 at 5:59 PM
