1993 Toyota Paseo
17,336 MILES • 4 CYL • FWD • AUTOMATIC
CHARLES1994
I changed my air filter, oil filter, changed my oil, flushed my cooling system,flushed my brakes and power steering fluid, filled my gas tank and used stp complete fuel system cleaner, and changed my spark plugs and my car still stalls out.
What do you think can be the cause of my car stalling out?
I also changed my back lights and when i turn the lights on they don't go on and i changed the fuse.
What can be the cause of that?
Thank You!!
Feb 18, 2009 at 10:29 AM
BILLYMAC
  • 2,204 POSTS
hi stalling can be caused by several things.check for loose or cracked vacum hoses on the engine.
check the throttlebody spray with carb cleaner.
have you changed fuel filter?
idle sensor may be a problem/. thanks billymac
Feb 18, 2009 at 10:38 AM
