1992 Toyota Paseo engine replacement
134,000 MILES • 4 CYL • FWD • MANUAL
ELJAYTEE
I would like to know how advisable and reliable it is to replace an engine in this model.
It's a very general question, i realize, but I've found a car I like and am willing to put a little money into it. I just don't know whether replacing a used engine with low miles has the same kind of assurances that comes from having an engine factory installed.
Jul 1, 2010 at 9:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
so long as you find a good, reputable shop to do the engine replacement then it can be a good choice to choose a cheap, used vehicle that needs work..since these vehicles will sell much cheaper than a driveable car. not only would you have the car cheaper than if it were already driveable, but you would also have a lot less miles on the motor than what the original already has.
Jul 1, 2010 at 9:52 AM
