water pump bolt broke
TOYOTA
DINGALANG
HAVE A 1994 2.4, RE . BROKE A BOLT OFF REPLACING WATER PUMP. EASE OUT BROKE ALSO, A FRIEND TRIED DRILLING BESIDE BUT DRILL PART OF THE ENGINE. HELP WHAT CAN I DO NOW???
Mar 7, 2006 at 9:13 PM
DINGALANG
[quote:8b39d29f8e="DINGALANG"]HAVE A 1994 2.4, RE . BROKE A BOLT OFF REPLACING WATER PUMP. EASE OUT BROKE ALSO, A FRIEND TRIED DRILLING BESIDE BUT DRILL PART OF THE ENGINE. HELP WHAT CAN I DO NOW???[/quote:8b39d29f8e] 1994 TOYOTA TRUCK, 133,000 MILES
Mar 7, 2006 at 9:15 PM
FISHERMAN
  • CAR REPAIR CONTRIBUTOR
  • 937 POSTS
did you tried to install the pump with out that screw?
is there another screw near that you can use to put pressure on the pump?
Mar 7, 2006 at 9:45 PM
DINGALANG
[quote:f854df5722="fisherman"]did you tried to install the pump with out that screw?
is there another screw near that you can use to put pressure on the pump?[/quote:f854df5722]
no, thought it would leak
nothing that i can see to put pressure on the water pump.
Mar 7, 2006 at 10:01 PM
FISHERMAN
  • 937 POSTS
how deep the screw broke?
hard to reach?
install the pump with some silicone sealer (red high temperature) you are short of options...
Mar 7, 2006 at 10:19 PM
FISHERMAN
  • 937 POSTS
i used to extract the broken screws, welding a piece of metal on it and turn in and out until it break loose... but in your case the space its small and hard to reach also the easy-ot broken and the drilled block... make it even harder...think abou it.. should be something...
good luck!
Mar 7, 2006 at 10:49 PM
