Toyota Camary LE 1992 (4 Cylinder)
1992 TOYOTA
KAPILMIRCHI
I got the
1. Timing belt
2. Water Pump
3. Accessory belts
changed in my car yesterday for $480 (including parts + labour)
Was that a good deal. Now I am being told that my front axel + break pads would also have to be changed
Front AXEL Parts + Labour = $250
Break Pads Parts + Labour = $140
Is this a good deal???
Feb 5, 2007 at 8:50 PM
Little bit on the high side-get another quote.
Feb 5, 2007 at 10:31 PM
LOSTINMARS
  • 222 POSTS
sounds about right using oem parts, which i highly recommend. there are a few parts missing though that should be changed as well. while off the oil pump should resealed ( about another $30 in parts) and the timing belt tensioner adj spring should be changed.
the labor time should be between 3.5 & 4.0 hours.
Feb 6, 2007 at 1:08 PM
