tire pressure
TOYOTA
MPJ111
  • 20 POSTS
I have toyota hilux surf.
Tire size is 265x70 R16
How much the tire pressuer should be in PSI.
Jan 12, 2006 at 6:12 PM
REDROTTIE123
There should be a sticker on the door panel stating how much air to put in the tires. Either there or maybe on inside of the glovebox door.Just go by that sticker, not what it says on the tires.
Jan 13, 2006 at 6:47 AM
MPJ111
  • 20 POSTS
I found the tag and it is in Japanies
KG/cm2
1.8 2.0
I belive this is tire pressure.
How much in PSI.
Any idea.
Jan 14, 2006 at 12:28 PM
ETOMENBANG
sorry, the link doesnt work up above but you can just go to the site www.drivegreen.com. . . then when you look on the right side, itll say CAR CARE and underneath it you need to click the auto tire pressure link. . and then you just need to select your car
Jan 14, 2006 at 3:52 PM
IANCYR
if you haven't gotten your answer yet im a tire technition I would run 40 psi.. unless they are 8 or 10 ply tires . also if you are carrying weight that would matter. but if no weight and the tires are regular 4 ply I would run 40 psi. hope that helps
Nov 3, 2012 at 7:20 PM
