Toyota Oxygen Sensor Change Interval
TOYOTA
JRMASSEY
How often should we change the oxygen sensors. Some say toyoto sensors seldom fails but other says it should be a part of regular maintenance. Should they be change with the timing belt like after ever 100000 km.
Mar 3, 2006 at 12:38 AM
FISHERMAN
  • 937 POSTS
the computer should tell you when they fail...
(check engine light)
never heard about to replace them as a regular maintenance.
Mar 3, 2006 at 1:57 AM
Suggested Repair
Do not replace oxygen sensors as routine maintenance or with the timing belt. Replace them only when the computer indicates a failure, typically with a check engine light.
Conversation Summary
The owner asked how often Toyota oxygen sensors should be replaced and whether they should be changed with the timing belt around 100,000 km. The expert said the computer signals failure with a check engine light and that oxygen sensors are not replaced as regular maintenance.
