my van and i are going to fight
TOYOTA
SPOOKIECHILD
86 2.2L van .
i got the pressure test done its all good and the clutch fan is fine . my question is , what would happen if i just removed the thermostat completely ? will it make it run cooler ? or will it mess something up ? i am now at my wits end here and going nuts over this
thank you
the spookie child
Apr 30, 2007 at 5:01 AM
BACKYARDMECHANIC
  • 337 POSTS
You probably won't notice much of a difference in the driveability or performance of the car, expect for warming the car up upon start up. The car will run cooler but will never reach the operating temperature it was designed to run at. This can effected emissions and gas mileage. I don't know what part of the country you live in and this may not be a problem now, come winter the car will have very litttle or no heat with the thermostat removed. I would find out what is causing the car to over heat or run hot and then replace the part that is bad. Remember the thermostat was put into the car because it was designed to be there not because the manufacturer wanted to spend extra money to put it there. If you are going to go to through all the trouble to remove it why not just replace it while you have it apart. Good luck :)
Apr 30, 2007 at 5:57 AM
DONSMALL
hey man do a google search for the toyota van "hose of death" and other overhesating issues. from the looks of this site it doesnt look like any toyota techs are here, or atleast are here for free.
Oct 14, 2009 at 3:51 AM
