1991 Toyota Erratic Idle With AC
TOYOTA
WCREW
My 1991 Toyota 4x4 (22RE 4 Cylinder) idles fine and runs great...except when I turn on the AC. Once I do this it idles erratcally when I press on the brake. I let off the brake and it idles normal. This only occurs if I turn on the AC. Once I turn on the AC this starts. I have changed the spark plugs distributor cap, did a value adjustment, change the PCV valve and replace all the belts and changed out the thermostat. From here I am lost. Please help!
Mar 11, 2007 at 8:32 AM
  • 75,988 POSTS
[quote:c784bdedd2="wcrew"]My 1991 Toyota 4x4 (22RE 4 Cylinder) idles fine and runs great...except when I turn on the AC. Once I do this it idles erratcally when I press on the brake. I let off the brake and it idles normal. This only occurs if I turn on the AC. Once I turn on the AC this starts. I have changed the spark plugs distributor cap, did a value adjustment, change the PCV valve and replace all the belts and changed out the thermostat. From here I am lost. Please help![/quote:c784bdedd2]
Check the brake booster and vacuum hose/check valve-also an idle up solenoid that increases rpm when an additional load such as the A/C
Mar 11, 2007 at 9:11 AM
Suggested Repair
Check the brake booster, vacuum hose, and check valve, and inspect the idle-up solenoid that raises RPM under an added load such as the A/C.
Conversation Summary
A 1991 Toyota 4x4 with a 22RE engine idles and runs normally except when the A/C is on, when pressing the brake causes an erratic idle that returns to normal when the brake is released. The owner had already replaced the spark plugs, distributor cap, PCV valve, belts, and thermostat and performed a valve adjustment. The expert advised checking the brake booster, vacuum hose, and check valve, plus the idle-up solenoid that increases RPM under A/C load.
