Toyota Performance Chip Claims
TOYOTA
KRYPTONITEFUSION
  • 15 POSTS
I was just wondering if any of those so called easy diy in 15mins and no tools required performance chips work. if u have been on ebay they are around and noticable. they claim to increase ur cars hp by 12-20hp.
I own a toyota this is why i posted this question here. I guess it generally applys anywhere.
Jun 10, 2007 at 5:51 PM
MIKE H R
  • 3,094 POSTS
The computer chips give a little more horsepower. they are easily put in, read the instructions carefully. You will see a diference in the gas miilage, it will get lower, if you don't have a performance engine and don't race do not get the performance chip, with that chip you have to change the thermastat. I have tried one on a 1995 s-10 blazer
Jun 11, 2007 at 3:52 AM
MMPRINCE3000
  • 133 POSTS
In order to increase HP you need more air in the engine. These chips generally add fuel and timing.
They are effective on turbo engines with electronic wastegates, they actually increase boost a few lbs.
Unless they can change the VVT (if equipped), I think they are a gigantic waste of money.
Jul 17, 2007 at 11:41 PM
Suggested Repair
Skip inexpensive plug-in performance chips. They generally add fuel and timing rather than airflow, so they will not meaningfully raise horsepower on a typical Toyota and can reduce fuel economy. They are only potentially useful on a turbo engine with an electronic wastegate, or if the device can actually change variable valve timing.
Conversation Summary
A Toyota owner asked whether inexpensive eBay performance chips that claim 12-20 hp gains actually work. One reply said chips can add a little power but lower mileage and are not worthwhile unless racing, citing experience with a 1995 S-10 Blazer. The expert explained that these chips mainly add fuel and timing, help only certain turbo engines by raising boost, and are otherwise a waste of money unless they can alter VVT.
