2001 Toyota RAV4 EFI Fuse Blows With AC
Note...the following I know...when the fuse blows, the motor is running and the air conditioner is on.
So, what do you think I should do....is there anyone in the central united states that could figure this out?
Toyota Dealership in my area apparently doesn't have the competence. please advise or send message to someone that might be able to help
thanks, joe
2. The EFI relay controls the Circuit Opening Relay @ the COR that's where all the Sensors gets their power. Any short beyound there will kill the EFI fuse.
3. Try this, remove the EFI relay, put new fuse in place and attempt to start it-if the fuse don't blow your problem is coming from between the EFI relay and one of the sensors
4. Not familiar with the color code on the Rav4
5. Does the fuse blows when you turn the ignition On or it blows later on? need to know before we proceed on.
6. My main target here is the Air Flow Sensor and O2 sensor circuit.
The way I fix mine I check every wire going to each sensor for short to ground. You just need a good electrician to find it.
7. Disconnect the MAF sensor and again turn the ignition On check whether EFI fuse blows
8. Just to let you know its hard to troubleshoot over the net. I don't believe on a trial and error replacement. Lets find it together with luck from above.
9. BTW am aware it will not start when ignition fuse is removed it kills the Ignition and Injectors. I was segregating between the Ignition and Fuel system. Right now your problem is coming from the EFI circuitry.
Good Luck!
joe
Do you have any codes?
let me explain a little more.....the fuse will not blow in the driveway when i turn on the a/c right now....it's like i have to be driving for a little while(warm it up)...then, after sitting at a stop light, i go to take off, and it's like the slight jerk or pull of the clutch (movement) pops the fuse(air conditioning ON). If the a/c is off, it runs perfect and continues to do so. Again...when i begin to put the key in the ign, the cooling fan kicks on....also, after i shut it off, it delays shutting off a second. Now...codes? YES...3 codes
p0100...mass or volume air flow circuit malf
p0505...idle control system malf
p0101...mass or volume circuit range performance problem
Try cleaning out the throttle body before you deal with the IACV.
Between these two MAF and IACV a wiring problem or the sensor itself will kill the EFI fuse look closely at the EWD.
Won't hurt to clean out the throttle body and plate. while checking the IACV ( Idle Air Control Valve )
EWD is the Electrical Wiring Diagram.
Get a book and bench test the MAF
how do i check the iacv
Suggested Repair
Do not replace parts at random. With the A/C on after warmup, check the A/C relay, EFI relay, and wiring for a short to ground. Follow the P0100 and P0101 codes by bench-testing the MAF and its built-in air-temperature sensor, clean the throttle body, and inspect the idle air control valve and its wiring using the electrical wiring diagram.
Conversation Summary
A 2001 Toyota RAV4 blows the EFI fuse and stalls when the A/C is used after the vehicle warms up, especially when pulling away from a stop. It runs normally with the A/C off; the cooling fan also comes on as the key is inserted. An ECU replacement did not help, and codes P0100, P0101, and P0505 are present. The expert advised isolating the EFI circuit, then checking the A/C and EFI relays, MAF and air-temperature sensor, throttle body, idle air control valve, and related wiring for a short.
