2002 Toyota Corolla Window and Mirror Out
TOYOTA
BAYVIEWIAN
I was thinking about purchasing a 2002 toyota carolla. Neither the drivers side window nor the passenger side mirror are working. It could be the motors, but it seems unlikely that two motors would quit on a 2002. What are some other likely causes?
May 25, 2006 at 7:09 AM
LOSONE
  • 1,616 POSTS
The most common cause of both not working is the common door switch. Go to a salvage yard and get a switch ands see if that will fix it.
Another cause might be that a young person owned the car and tried to add a door speaker and disconnected or cut the wires.
May 26, 2006 at 10:33 AM
Suggested Repair
Test or replace the shared driver door switch, using a salvage-yard unit if needed. Also inspect the door wiring in case it was disconnected or cut when a speaker was added.
Conversation Summary
A buyer considering a 2002 Toyota Corolla reports that the driver-side power window and passenger mirror do not work and doubts that both motors failed. The expert says the shared door switch is the most common cause and suggests trying a salvage-yard switch. Another possibility is wiring disconnected or cut during a door-speaker installation.
