Can a car pass smog with a leak?(Oil,water.ETC.
TOYOTA
RZQ446
  • 6 POSTS
Im just wandering if a car can pass a smog test with a tranny leak?not severly leaking,but only when the wheels move.(Worn axle seal)
Mar 12, 2007 at 1:30 PM
CHEVY22
  • 1,375 POSTS
you should be fine but i would recommend replacing that seal , its a 5 dollar part that could lead to a thousand dollar repair if it gets worse
JIM
Mar 12, 2007 at 1:36 PM
RZQ446
  • 6 POSTS
thanks and yah i will replace it after it passes smog cause i cant drive it while its a non-op
Mar 12, 2007 at 1:39 PM
CHEVY22
  • 1,375 POSTS
no problem
Jim
Mar 12, 2007 at 1:43 PM
RZQ446
  • 6 POSTS
Hi,i have 1 last question that really confusin me,i have a 1987 Toyota celica ST,which has 155,xxx miles and its a 4-cylinder FE.The problem is that when i accelerate off a stop sign it will go but when i floor it,the gas gauge goes down and i have no acceleration or power.I asked the dealer whats wrong with it and all they told me was to clean my fuel injectors.So,i just recently put a STP Fuel Injector cleaner but not sure if its working.Everytime i hit the gas all the way down it will rev to 2000,then climb slowly.Do you think it could be my injector,fuel pump,or just a clogged catalytic converter.
I will be apreeciated with cooperative answer,Thanks
~rzq446~
Mar 12, 2007 at 1:47 PM
