2008 Toyota Yaris Bump While Driving
TOYOTA
BST82551
I keep experiencing a bump bump bump bump as I drive. It doesn't happen when the engine idles. When the wheels go faster, the bump bump bump gets faster.
I was recently pushed off to the side of the road and slammed on my brakes as I skidded into a grassy area. I have no antilock brakes. I own a 2008 Toyota Yaris.
I was thinking a bump in the tire, but I've found nothing so far. Perhaps a problem with the brakes?
Brian
Oct 24, 2007 at 5:05 AM
FISHERMAN
  • 937 POSTS
[quote:1d8a3526bf="bst82551"]I keep experiencing a bump bump bump bump as I drive. It doesn't happen when the engine idles. When the wheels go faster, the bump bump bump gets faster.
Brian[/quote:1d8a3526bf]
Hello !!
Check your front tires..
Sometimes the belts inside get broke because a "hole on the road" or a hit on the curbe...
that its hard to "see" but easy to "feel during driving"
Good Luck!
Oct 31, 2007 at 3:47 PM
Suggested Repair
Inspect the front tires for internal belt separation or damage from a pothole or curb impact. The defect may not be visible but can be felt as a rhythmic bump that increases with wheel speed.
Conversation Summary
The owner of a 2008 Toyota Yaris reports a rhythmic bump that speeds up with wheel speed and does not occur at idle, after being forced off the road and skidding into grass without ABS. The expert advises checking the front tires for broken internal belts from a road impact or curb hit, which are hard to see but easy to feel while driving.
