Broken rocker arm!!
TOYOTA
RESISTANCE
Hi, I recently bought a second hand 2E engine for my Starlet, I discovered that a Rocker arm was broken and has fallen off.
I also discovered that the previous owner has changed the whole crank for one of a 4E engine. The 2E engine has 4 balances while the 4E engine has 8, but all the other things seem to be the same.
Here is the question: What could be the reason/ problem that the Rocker arm has broken off?
Feb 10, 2006 at 2:12 AM
2CARPRO JACK
  • 11,533 POSTS
hit a valve maybe
Feb 10, 2006 at 6:03 AM
RESISTANCE
What could be the problem if a piston hit a valve? :?: :?
Feb 10, 2006 at 5:34 PM
