1989 Toyota Mark II AFM No Start
TOYOTA
MUSTAFA885
  • 9 POSTS
Hello all,
I have a toyota Mark II 1989 Model, 2000cc, 211000Kms. Yeah I know Old. Anyway sometimes the engine fails to start. It cranks and fails to start. But When I unplug the wire to the Air Flow Meter it cranks and starts. It Idles and when I accelarate engine stops. Also when I plug it back in when idling the engine stops.(Some times it continues and I drive off). I try starting again with the wire plugged in it just cranks and jams to start, only starts when I plug out the wire. So What I do is fiddle with the wire plugging it in halfway sometimes it starts some times not.
Usually happens in the morning. Help. Thanks :D
Sep 12, 2007 at 3:25 AM
  • 31,937 POSTS
Hi there,
It sounds like your in the right place to start looking for your fault. i would check that all the terminals in the plug are clean & free of corrosion. Make sure that the plug locks in tight and that there is nothing stopping the plug from going all the way home. Also check that all the wires are OK, with the plug disconnected, gently feel that all the wires are tight and that the pins are also tight in the socket. If you suspect that there is a problem in the plug, an auto electrician will easily repair any faulty connection.
Mark (mhpautos)
Sep 12, 2007 at 10:35 AM
Suggested Repair
Inspect the airflow meter connector: clean any corrosion, confirm the plug seats and locks fully, and check that the wires and pins are tight. Have an auto electrician repair any faulty connection.
Conversation Summary
A 1989 Toyota Mark II sometimes cranks but will not start, usually in the morning. Unplugging the airflow meter lets it start, but it stalls when accelerating or when the connector is plugged back in; partial connection sometimes works. The expert recommends checking the plug for corrosion, full seating, tight pins, and sound wiring, and having an auto electrician repair a faulty connection if needed.
